erwinlogs
Posted on - 08/05/2011
Hi guys,
While I was working to encode some inventories using Microsoft Access, I received an error message.Â
Microsoft Office Access
Microsoft Office Access has stopped working
A problem caused the program to stop working correctly.Â
Windows will close the program and notify you if a solution is
available.
                             Close program
I restarted my computer in hope that it's just a minor glitz, but when I am opening the inventory application, still I can't work on my task because of the same error message. Please share some solution on this problem.
zobia
Microsoft Office Access suddenly stopped working
Hello Erwinglogs,
You have to check which windows you are using. Is it registered? You must have to update the previous or the best thing is to uninstall it and download the new and latest version from a good source and make sure that your system supports the latest version.
Other thing is that there might be some corrupted file or some virus which is resisting the running of MS Access. So try to scan your computer and repair the windows and other files. Do this in normal mode or the best thing is to do it from a safe mode.
There might be some corrupted file in MS Access. You should check the files and also the file format before opening the file.
Have a good day!
