Microsoft Office Compatible With Windows 8
Hi, I do not have a technical background at all. I would like to know which version of Microsoft Office is compatible with Windows 8? Please reply ASAP, Thanks in advance.
Hi, The following are the choices of versions:
• Office 2013
• Office 2010
• Office 2007
• Office 2002
Office 2002 is about to lose support from Microsoft, so that it would be a bad choice. Office 2007 is decent and 2010 being my personal favourite. Office 2013 is built for Windows 8 specifically. But Microsoft Office 2013 has compatibility issues and some standard system requirements.
To check system configuration:
• Right click on My Computer
• Select Properties
So Office 2010 shall be the best and most versatile version that would work seamlessly without any compatibility issues in Windows 8.
