shahzad1987
Posted on - 08/12/2012
During the installation of MS office i have faced an error 1706.
I tried to resolve this problem but not successful till yet.
I think it is related to Microsoft office Cache, either it is crashed or corrupt. I just delete it but after that i'm facing same problem.
Also, i check my network connection, it is OK as well as CD-Room Drive.
Configuration Error is shown below:
Exact Configuration Error is:
Microsoft Office Professional Plus 2010
Configuration Progress
Error 1706. Setup cannot find the required files. Check your connection to the network, or CD-ROM drive. For other potential solutions to this problem, see
C:UsersykAppDataLocalTempSetup00000600Setup.chm
Setup failed. Rolling back changes…
Anyone help me how to fix that error.
Waiting for your best response.
thanks,
Microsoft office Configuration error 1706
Hi Shahzad,
One of the reasons is that, you may need to acquire Administrator login. Check if you have this permission  first.
Check if your CD ROM is properly inserted and that it is not damaged. Try to wipe the CD first and try to reinstall.
If these does not work, From the Start menu, go to Run and type offcln.exe.
From there, delete all Office applications before finally reinstalling Office.
Good luck!
For removing Microsoft Office Configuration Error 1706 you have to Ensure on other version of Microsoft Office is currently installed on the computer. Uninstall it using Add / Remove Programs from Control Panel if it’s installed.
 If the uninstall fails use the 'Fix-It' tools available here to remove the required version of Microsoft from the computer and then try to install Office 2010.
It is necessary to fix office 1706 error code because it may be the cause of missing files. Sometimes Office files gets corrupt due to this error. In order to resolve this error code you may follow some manual steps. Some of them are:
Turn on your PC or laptop and login as an Admin.
Go to > Start > All Programs > Accessories > System tools > Click on Restore
In the next step Click on Restore my PC to an earlier time and then click on Next.
Choose the most up to date option and select restore date. Click Next button.
Click the Next button in the verification screen.
Restart your system when restore completed.
