Microsoft Office Excel crashes on Exit
MS Excel 2003 crashes every time I close it. I get an error message saying that “Microsoft Excel has encountered a problem and needs to close. We are sorry for the inconvenience”.
I have tried re-installing Microsoft Office, and this has not fixed the problem.
The same problem goes with MS Word when I try to save a document.
Best Answer by mathews.m
Answered By 0 points N/A #126666
As you said your problem still persists even after re-installation MS Office 2003.
That means you have a problem with your operating system .
The best way to overcome this problem is you have to format the system only and install new operating system again.
This is the perfect solution to the problem.
Answered By 0 points N/A #126668
Root cause of this problem (Microsoft Excel has encountered a problem and needs to close.
We are sorry for the inconvenience) is Excel extension for Bluetooth.
Solution:
How to Fix:
  • Click on Start > Run > type in "regedit" > click on Ok
Registry dialog box appears.
Navigate by going to the following registry key which can be seen as a pane in the right of the registry editor
  • HKEY_Local_Machine
    • Software /Microsoft /Office/Excel /Addins /Microsoft.Education.Office.Addin.Connect
  1. Double click loadbehavior
  2. Change the LoadBehaviour to the value of "0".
For Microsoft Word
    • Software /Microsoft /Office /Word/Addins /Microsoft.Education.Office.Addin.Connect
