Microsoft Office file type blocked by File Block setting
Hello tech people,
I encountered a problem while working with the Microsoft Visio 2013 application. While working it throws an error message ‘you are attempting to open a file type that has been blocked by your file Block settings in the Trust Center’. I am not able to proceed with the help it provides. How do I fix the issue? Any one facing the same error problem please help me to fix it. Thanks.
Microsoft Visio
You are attempting to open a file type (Vision 2003-2010 Binary Drawings, Templates and Stencils) that has been blocked by your File Block setting in the Trust Center.
This error occurs when you open a Microsoft Office file type blocked by File Block setting in the Trust Center. To enable this file type, do the following:
- Click the File tap
- Click Options.
- Click Trust Center, and then click Trust Center Settings.
- In the Trust Center, click File Block Settings
To open documents with this file type, disable the registry policy setting. For more information, see Microsoft Knowledge Base article 922850
