Microsoft Office FrontPage opening File Error
I want to open an HTML file in FrontPage. I download one file from internet.
Its extension is .htm now I want to open this file in the front page for this purpose I do right click at that file then I click at open with now I select front page but I am receiving this error.
Server error: There is no file with URL ‘SHATTERED/introduction.htm’ in this web.
                                                OK
Answered By 0 points N/A #121015
Hai
Sometimes this error might occur because of the “SHATTERED/introduction.htm” document is edited on some other versions of the Microsoft Office FrontPage. Other versions of MS Frontpage might not support the file extension type .htm.
In this matter you have to check whether the FrontPage Server Extension components are installed or not.
To download FrontPage Server Extension components you can use the following URL
https://msdn.microsoft.com/en-us/library/aa140185(office.10).aspx
And after downloading the components you can get an idea how to install them by using following URL
https://technet.microsoft.com/en-us/library/dd349940.aspx
And is there no problem with the server extension components of the Microsoft Office FrontPage, you can change the URL extension into html and try. This might work for you.
