How can I prevent errors during the setup of Microsoft Office Home and Business 2010 like the error message below? Please help. Thanks
Microsoft Office Home and Business 2010 encountered an error during setup.
Error 1935.An error occurred during the installation of assembly component {E9192F0E-035C-32C5-A6A7-6D781EE24B3D}. HRESULT: 0x80073712.
Hello Herron,
Error 1935 Installing Office Home and Student 2010 on Windows7.
This problem may occur for the corrupted installation source or previous version of Office on your PC.
I hope this will solve your problem.
Thank you and have a good day.
Hello Paul A Herron,
              If you want to remove that error then you need to install the software using the administrative setting. I suggest you to install any software using the same setting so that it can occupy those resources that the software require. All you need is to start the software again using the option of "Run as Administrator". I hope that thing can fix the error that you are now getting while installing the software.
