Microsoft Office Install Error 1935 While Installation –solution
Hi, while installing Microsoft Office 2010 I get an error displaying as Error 1935 occurred during the installation of assembly component. Give me a solution for Microsoft Office install error 1935, thanks in advance.
Image result for Office install error 1935
Answered By 0 points N/A #294770
Hi, You get this error because previously installed dot NET framework of the higher version, compared to your Office suite had. So when you get ‘error 1935’ while installing office 2007 or 2010 or any standard alone office products, restart your PC and try to setup again. If you still got same error run the system Update Readiness tool.
Repair or update Microsoft dot NET framework components or re-install dot NET framework components. Stop windows search services in services.msc. For detailed information there is a detailed article on the Microsoft support, click here to see.
