Microsoft Office for Mac 2011
I tried to boot Microsoft Office onto my Mac 2011 only to receive a problem report. It said that this product needs an Intel-based Macintosh pc. Can you tell me what this means and what I need to do to fix it?
This kind of problem is not quite that difficult or a major problem. This problem may occur/happen if your computer doesn't meet the minimum system requirements for the Microsoft Office for Mac 2011. It is because the MS Office for Mac 2011 requires an Intel-based processor. You can check
To check if your computer meets the required system, just follow these simple steps:
Step 1:
– To install Office for Mac 2011, quit all the applications first.
Step 2:
– Determine your processor type.
