I had this product activation failed in all of my Microsoft office at the top of my screen.
Every time i open it there's nothing that pops up for it to be activated. Everything seems to be normal though when i use it.
I'm wondering where will i go to activate my Microsoft office?
What are the consequences if i didn't activate it?
Microsoft Office Product Activation Failed
Hey, can I ask you something? Where did you purchase your MS Office by the way? If there’s an error in the activation code, then you contact your vendor or the store you have purchased it, or if you have purchase it on the internet, contact them they maybe they are sending you a wrong activation code. That will be the first option. But in case you need to troubleshoot the problem. Try by doing this.
First is to open you Outlook and click the file tab, click on help  in the upper left of your screen. Now take a look on the right side and click the Change Product Key, you enter correctly the key that was provided by the vendor. Now check the Activate Automatically box, then restart your office, once done click the file tab then help, you will see on the right side if the product is activated.
