Microsoft Office Professional 2010 – Microsoft .NET Framework 4
Recently I installed Microsoft Office Professional 2010 as well as with it came Microsoft .NET Framework 4.
But Norton Ghost 15 (V 15.1.0.36526) doesn't look like to know this and shows with this error message through the install process. I ignore the error and then continue the install process and also the set up seems to ok, however I think there could be a few elements that's are not running correctly but I am unsure.
I need to know about this error and also I need to solve it. Please help me.
Norton Ghost Installer Information
ERROR:Failed to have success running
InstallVSSProvider function in MSIInstallVSSProvider
Function.
                                  OK
I ignore the error and then continue the install process and also the set up seems to OK, however I think there could be a few elements that's are not running correctly but I am unsure.
Please help me.
Best Answer by Hathy greave
Answered By 0 points N/A #159925
To get rid of the problem you have to do the following:
1. Uninstall the Program, Norton Ghost.
2. Find COM fix file and download.
3. In the Windows directory usually (C:) create a new folder namely COMFIX and extract the COM_Fix.zip file what you download now.
4. Go to C:COMFIX and right-click on com_fix.bat file and Run as administrator.
5. When you see Restore Successfully! message, click OK.
6. Exit all programs and restart your computer.
7. Now install Norton Ghost.
I think your problem has been solved.
Hathy
Answered By 0 points N/A #159926
Dear User,
You can easily fix this problem following these steps,
  1. First uninstall Norton, Microsoft Office Professional 2010 and also .NET Framework 4 completely from your computer. Then restart your computer.
  2. Now install Microsoft Office Professional 2010 in to your computer along with .NET Framework 4.
  3. Then install Norton Ghost (make sure you install a newer version)
Thank you
Answered By 590495 points N/A #306918
Norton Ghost 15.0 requires .NET Framework 2.0 or higher but since you already installed Microsoft .NET Framework 4, it should work. But unfortunately, it doesn’t even install. According to its documents, you can install Norton Ghost 15.0 even without the required .NET Framework because you can install it later after installing Norton Ghost. But since it doesn’t install, I guess you should install first the required .NET Framework.
Download Microsoft .NET Framework 2.0 Service Pack 2 and install it. Once installed, try installing Norton Ghost 15.0 again. See if this works. If this doesn’t work, there is probably something wrong with your installer. Try downloading Norton Ghost again.
