Microsoft Office Professional 2010 Trial encountered an error during setup
Could you please elaborate more on this error during installation of MS Office Professional 2010? What can I do to prevent the installation process of encountering this?
“Microsoft Office Professional 2010 Trial encountered an error during setup”
Best Answer by Joseph A Reese
Answered By 0 points N/A #175651
Dear user,
For this problem, follow these steps:
I will recommend you to re-register the Windows Installer and in the %TEMP% folder, check for permissions and in the C:WindowsInstaller folder for having full-control.
For re-registering on the Windows Installer, run these commands:
msiexec /unregister
msiexec /register
Hope this will help you.
Thank you.
Answered By 0 points N/A #175652
To Solve your problem. Try the following instruction:
1. Try to rename the ‘Microsoft Help’ folder.
2. Then click to  install the Office 2010 package .
Please follow the steps given to rename:
1. First Click on Start Manu -> All Programs-> Accessories -> Run.
2. In the box Type %Programdata% and Click OK.
3. Then  rename the 'Microsoft Help' folder as 'Microsoft Help. OLD'.
Now check if it works. Best of luck.
