Microsoft Office Visio Viewer 2007 A network error occurred
Hey guys,
I am currently connected to my home LAN which has all the computers in the house hooked and I was trying to import images to my Microsoft Office Visio Viewer but all am getting is this warning message on screen:
A network error occurred while attempting to read from the file C:Program FilesMSECacheviewervisioviewer.msi
        OK
Anyone who knows how to go about this problem?
Best Answer by Tristan Wood
Answered By 0 points N/A #123786
Hi Nelly,
Is this a new install of your Visio Viewer? an upgrade? or have you made any changes on your system?
There is a possibility that the system could not find the file it was looking.
Try to look for the file name "visioviewer.msi" on your folder by going to drive C:>>Program Files>>MSECache>>vviewer>>look for file name visioviewer.msi
If you see "visioviewer(1).msi", you have to rename it "visioviewer.msi"
If youare still experiencing this issue, another solution would be to COMPLETELY UNINSTALL the program. If you have windows XP, click START>>CONTROL PANEL>>ADD OR REMOVE PROGRAMS>>CHANGE OR REMOVE PROGRAMS>>look for visioviewer>>click CHANGE/REMOVE.
Restart your computer.
Reinstall you visioviewer.
Hope this helps.
Answered By 55 points N/A #123787
Go to this link and see if it helps you out. It states that you need a fix to solve the problem. It also says that you can perform a complete new installation but i usually don't recommend it as it is a hefty and lengthy process and you might do something wrong in it if you have never installed it.
After that go to the installation directory of the viso viewer. Normally its in C drive.
When you reach there look for the fie named "visioviewer.msi" .
if it is written like visioviewer.msi(1) or (2), then please rename it and remove the later part of the file name.
This will surely help you out.
Answered By 0 points N/A #123789
Hello Nelly,
With these solution you can also apply another method to solve this issue. Get that one method from this Techv page.
http://Network error occurred while using Microsoft Visio Viewe
