Microsoft Office Word has stopped working
I use Office 2007. It was running smooth, but last couple of days, when I try to close the program a message
Microsoft Office Word has stopped working" is continuously appearing.
I don't know why such happening.
Don't it have any solution?
Error:
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is
available.
        Close program
Best Wishes,
Dominic
Best Answer by zishami8
Answered By 0 points N/A #88908
This type of problems occurred with some scripts start running on system or some file of the running program face crash and loss.
First take a look on have you install any new font package, may be it creating trouble to running MS word. I also face this type of problem that is purchased from market instead of proper company license.
Solution of this problem is only that you must update or reinstall the full MS office. Please be sure before installing new, fully delete previous otherwise it will again create error. And also restart computer before install new one.
Answered By 0 points N/A #88910
You can have this issue resolved by working in a Microsoft Safe Word mode. Follow these steps;
1.       Go to START > All Programs > Accessories > Run > then type this “winword/safe”
If this works without creating any problem then you must disable add-ons on it.
·         On File menu choose Options > Add-ins > Go button: com-in add.
·         Check all if there are ad-ins in the list; clear the checkbox to disable all.
·         Close and restart the word.
