Hi everyone,
I have installed Microsoft Office Word and got an error message trying to open XML file. I really tried to demolish this error but couldn’t get any success. How can I fix this issue? Your help would be really appreciated. Thanks for your cooperation.
The Open XML file Archive.dotx cannot be opened because there are problems with the contents or the file name might contain invalid characters (for example, V).
Details
The file is corrupt and cannot be opened.
Microsoft Office Word XML file error
The file you are trying to open, Archive.dotx, is a Microsoft Office Word template file. It is a template used for creating new Microsoft Office Word 2007, Word 2010, and Word 2013 files that don’t have or don’t contain macros. It is the default file format used when creating your own customized template in Microsoft Office Word with no macro.
There is also no problem with the filename used because it doesn’t contain any special characters. Since there is no problem with the filename and the file format is supported, it seems the problem has to be with its contents which are probably unreadable. Since it is a Microsoft Office Word template but it can’t be opened by Microsoft Office Word, it means the file is corrupted.
If you don’t have a backup of your template, I guess you have to re-create your template from scratch. For more info on recovering corrupted document or template, go to How To Recover A Corrupt Document Or Template. For more info on the supported file formats, visit Microsoft Office Word Supported File Formats.
