Microsoft Office2010 OneNote converter needed.
Generally I use Microsoft Office2007. Recently I installed Office2010 and try to use this. Here I have about 100 Evernotes. Now I require converting this Evernotes into OneNote.
Anybody can say what is the procedure to do this? Is there any converter that can do this or there is any other easier method to do this? Please tell me.
Best Answer by Michael Moroe
Answered By 5 points N/A #113625
Hi Steve90,
Converting Evernotes into OneNote, you need to have a converter and that software can be downloaded on the Internet. This software converts the existing notes you have into OneNote.
Once downloaded, you will be ask where to specify the folder you want to import the file and you'll need to save the file according to what folder you want to be in. These list below are the benefits of having this tool.
Features:
  • A user-friendly desktop application.
  • Compatible with Windows computers.
  • Lets you import Evernote notes to OneNote.
  • Lets you select the note attributes you want to import.
Evernote to OneNote converter is a tool that convert into much easier way.
Here is the link
Hope this helps.
