leslie
100 points
Posted on - 02/18/2012
Hello.
I am currently using Windows 7 as my operating system. I am running Microsoft Outlook 2007 on it using a Gmail ID (POP3). Whenever I tried to send or receive emails, I get the following error message: "Reported error (0x8007000E): 'Out of memory or system resources. Close some windows or programs and try again."
I don't know why this error keeps showing up,
Because I don't use any other operating system or run any program whenever I use Outlook.
Please help me.
Thank you very much.
Microsoft Outlook 2007: Error in Receiving and Sending Emails
Hey dear, it is a common problem for Microsoft Outlook 2007. There are few reasons that may cause error in sending and receiving emails in Microsoft Outlook 2007. It may be happen due to damage of MAPI32.dll file. You have to fix this file using MAPI Repair Tool.
You may find the file Fixmapi.exe that have to fix on the folder C:WinntSystem32 or on the folder C:WindowsSystem32. Then another case, your email profile may be damaged.
Please create new profile and restart Microsoft Outlook 2007.
Another case may be occur,do not mind please. There may a corrupted email message.You may check this by moving messages. The damaged message will not move.
You have to delete it. If this is a important email and you do not want to delete it, you have to repair Outlook PST. To repair Outlook PST you have to buy software from market.
But before trying the methods above remember that the problem you faced,may be also due to Microsoft Outlook 2007 used much memory. So close all program including Microsoft Outlook 2007 and reopen Microsoft Outlook 2007.It may solve your problem.
