Not the whole Outlook "My Calendars" illustrates up in CPA. Recently, I am applying MS Outlook 2007 however what has been programmed on "My Calendars" is unavailable on CPA. Moreover, I have observed that several of Outlook appointments (on the calendar that is planned on CPA) merely illustrate up on Outlook and not brought over to CPA. Anybody recognizes troubleshooting regarding this matter?
Microsoft Outlook 2007 troubleshooting problem
Hello Taken Crawler,
If you did an upgrade recently to your Calendar Printing Assistant in outlook, and you possibly upgraded to the 64 bit version of that application, then that may be the cause of the problem.
The 64 bit application seems to have a calendar printing assistant that will allow you to see the schedules when you use the calendar view, but the problem is that you cannot be able to print all of the calendars. I do not know if there is a remedy for that yet, but I will suggest that you try downgrading the calendar printing assistant.
Hope this helps.
__
Regards
Mahesh Babu
