Microsoft Outlook 2010 Address Book Not Visible
I like to use Microsoft Outlook as my email client. While finding contacts, I saw that the Outlook 2010 address book did not show all of my contacts. Please help.
Outlook allows contacts to be synced even from custom folders. To solve your problem, you can follow the steps given below.
1. For Microsoft Outlook 2010, you can install the application called Outlook Address Book Service. This is available as a package in your current Outlook application.
2. Next, you can specify the contact folder in case you are using a custom folder. Under the Properties tab, type in the name of the address folder.
3. Now go to your contacts folder and make sure the email addresses are synced.
