Microsoft Outlook experienced a serious problem with the ‘pdfmoutlook’ add-in
Hi Experts
Recently I upgraded my system to latest version. After the upgrade, I started getting this error message often. This is not creating any major problem in the computer but this is very annoying to me. I am not sure whether this will create a problem in future. What is this add-in? How do I fix the error? Please suggest me some solution. Thanks.
Microsoft Outlook
Outlook experienced a serious problem with the ‘pdfmoutlook’ add-in. if you have seen this message multiple times, you should disable this add-in and check to see an update is available. Do you want to disable this add-in?
Yes No
