Jeo Tolbert
Posted on - 12/11/2012
Hello Friends,
Microsoft Outlook has encountered a problem on my machine running with Windows 7.
It has failed to open the Outlook Window. I do not know the reason behind it.
Have you any idea for the issue?
Please help me to solve the problem.
Thank you very much.
Outlook.exe/resetnavpane
Microsoft Outlook has encountered problem on my machine running with Windows 7
The problem can be caused by many things. Try these solutions to fix your problem. First of fall try to update your Microsoft outlook and then run it. If it didn't work. Follow these solutions.
1. On your keyboard there will be button having a logo of window press it with the R button. (Windows logo + R)
2. A popup window of a run will open type Outlook /cleanprofile and then press enter.
It will clean your outlook from unwanted registry. Open the Microsoft outlook now. If the problem not solved try this then To check out the problem is not created by Add-ons.
1. Window logo button + R.
2. Type in run Outlook /safe.
It will open Microsoft outlook in safe mode and disable add-ons. Check your outlook that its working fine in safe mode then the problem created by these add-on. Disable third party Add-ons on Microsoft Outlook. If the problem persist then try fixing it online by Microsoft. Here is the url for fix it for me.
https://support.microsoft.com/en-us/fixit/en-us
louis
Hello Jeo Tolbert,
Sometimes I also faced this types of problem during open Outlook Window on my computer. To avoid this problem you need to download and install OutlookConnector. After that if problem your not solve just uninstall your whole Microsoft Office from control panel. Then restart your PC and again install your product Microsoft Office 2007 properly and configure your email address on outlook. I think your problem will be solved.
Thanks and Regards
Louis
