I have the capability of gaining web email access of my Microsoft Word e-mail. One issue I am having is that I can review with preview pain split screen.
Any suggestions ?
Will this atomic browser make a difference.
Best Regards,
Adam Gilcrist
Sammy1
Microsoft Outlook WEB EMAIL!!! Question inside
Good day;
It would be nice to know which version of Microsoft word you were using. Because with the current versions of Microsoft now a days. they are all set to their default view. But for you to change the view you are currently seeing, you need to check the settings of how the view is set.
By clicking on the view button on the very top left corner of the window,this is where you can change the current to other options of how you would like to see your preview.
Here's how to use preview pane in Microsoft Outlook. This allows you to split your inbox or other folder screen view in preview pane. To use and read in preview pane, just choose or select the message in the list and the message will display in reading pane.
Here's how;
1. Open Microsoft Outlook, go to View
2. A menu bar will be shown, select Reading Pane
3. Select Right or Bottom
4. This should let you read in pane
Here's how to hide the pane;
1. Go to View, select Reading Pane
2. Select off
There you are, these steps should let you view in preview pane.
