Microsoft project 2013 doesn’t show project online custom fields
I am using Microsoft project 2013 and I have 20 tasks level custom fields. Whenever I open project to edit the fields, I only see a few instead of all. Why is this happening? How can I show all the custom fields on the task information?
Answered By 5 points N/A #200267
Happy to support you!
One of the reasons for your issue can be that the data is not entered and formatted correctly.
If not, try scroll down task and resource the custom fields to assignment level and check.
It can also be that you have not copied the custom fields to the global template, which can result in making some custom fields to be visible only for the current project & for the other projects; you would have to recreate them. So, verify this issue and go to organizer & copy the fields to have them all displayed in new projects.
