jamali
Posted on - 10/25/2011
I used Microsoft security essentials. It was serving good. But for some days I am facing problems. It can't delete virus named 'Recycler'. I want it removed from my PC. Which anti-virus software is best suited for this. Give me a suggestion please.
RobertL
Microsoft Security Essentials could not remove Recycler virus
Try using Malwarebytes’ Antimalware and run a full system scan. You can get the installer from here:
https://www.malwarebytes.com/premium/
You can try going into Safe Mode with Networking by hitting F8 when you boot the computer up. Select Safe Mode with Networking and login. As soon as you’re in, you should be able to have an internet connection, open the link provided above and download the file then install. You should be able to install it and run a system scan in Safe Mode with Networking. I’d suggest doing a full system scan. As soon as it is finished, it should give you a summary of the infections detected and an option to Clean/Remove the infections.
Hi….
This is a huge problem that most of the people facing every day. Because most of the antivirus software not doing their work properly. Most of the people do not think about their antivirus software well. But I think it is the most important software that you should focus on.
There are lots of free antivirus softwares in the internet. But they do not do their works well. Here is the list of best antivirus softwares in 2001.
Follow this link
http://www.toptenreviews.com/software/security/best-antivirus-software/
Bit defender is good. But for the Microsoft environment I recommended Kaspersky Sky as the best antivirus software.
Thank you….
