Microsoft SQL Server 2008 R2 Setup Error
SQL 2008 R2 iso file extraction Error
I download this software from the Internet. Its extension is .ISO. I extracted this software with Magic ISO and now I am trying to install this software but I am receiving the below error.
According to my point of view this file is not properly extracted. Tell me the correct reason and solution.
The following error has occurred:
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2337.
Best Answer by Matt Drew
Answered By 0 points N/A #121023
Hello Angel,
As the error says, "This may indicate a problem with the package" so basically there is nothing wrong with the extraction. The possible error was upon compression of the file, errors might have been included. That's why, you are receiving an error. Making the file useless.  If you have tried extracting and installing again the problem will persist.
The best way in solving this, is by downloading the file from another source and do please read comments in order to be sure of the content. Comments and ratings are a good sign that the downloaded material is reliable and functional.  Or you could actually purchase the software, so that it would be really licensed and to minimize such problems from arising.
Answered By 0 points N/A #121024
I think this error appears, as you did'nt install SSRS and database Services.  So I think that you need to rollback the server and start again.  You can follow these steps:
Installation languages should be available on your SQL server;
Identify the decimal iden.language number and then from your Control Panel, choose regional language ; then options and then location.
You may need to see this solution too:
I think you may need .DLL replacements and extract ISO from it and then install in fresh box ; then you won't see any  error messages again.
Hope these methods will help you.
