Hall Allen
80 points
Posted on - 10/16/2012
Microsoft SQL Server 2012 has encountered a problem with the PowerPivot for Excel setup.
Have a look at the error message below. It is claiming about the missing of some prerequisites.
How can I get those prerequisites? Have you any idea for the issue?
Please help.
Microsoft SQL Server 2012 PowerPivot for Excel Setup
Setup is missing prerequisites:
This add-in requires the Microsoft Visual Studio 2012 Tools for Office Runtime and the .NET Framework 4.0. For more information, go to https://docs.microsoft.com/en-us/previous-versions/sql/sql-server-2012/ee210599(v=sql.110).
For general information,
Go to https://www.microsoft.com/en-us/download/details.aspx?id=29065.
Hello Hall,
In order to fix that issue, you will need to reinstall the Visual Studio 2012 tools. Another workaround will be to download the Orca MSI Editor and after that run a full validation. You will need to get rid of the CustomAction and after that you can go ahead and install PowerPivot.
Nicke
Dear Hall Allen,
1. When you have an error message, you must read it, as it contain the solution, to complete your installation go to this link in the error message.
2. Go to https://msdn.microsoft.com/en-us/library/ee210599(v=sql.110).aspx
3. Download a file with size of 1 Kb.
4. Read the rest of instruction on the website.
It should work well but if you found any further problems try to uninstall the program and clean your registry with any registry cleaning software, then do the steps as above.
