MS-SQL Error on removing a column using SMO
Hi guys,
I am trying to figure out why I can add a column to a table using SMO, but when I try and remove a column, I get an error which indicates the following:
You cannot perform operation Remove on an object in state Existing. (Microsoft.SqlServer.Smo)
That makes no sense. Surely when you remove a column, the state is Existing.
The code used to add and remove is as follows:
myTable.Columns.Add(myColumn)
myTable.Columns.Remove(myColumn)
I did a little searching on this but could not get any solution. Does anybody have some clues?
Waiting for reply.
