Microsoft SQL Server Management Studio Restore Failed for Server Error
Hi Expert DBA’s,
In Microsoft SQL server Management Studio when I try to restore the server failed to do. The error says the database is in use, but no one is using the database. I do not understand where I went wrong. Please guide me or help me to trap the error. Your help is great. Thanks.
Restore failed for Server ‘1       1’. (Microsoft.SqlServer.Smo)
Additional Information:
System.Data.SqlClient.Eeclusive access could not be obtained because the database is in use. (Microsoft.SqlServer.Smo)
Answered By points N/A #167956
This error usually happens because of a process that was being used by the database has been unexpectedly terminated without releasing resources or other user/session that was using the database at the same time.
To fix this issue, first, try to restart the “SQL Server” service.
  1. Go to Control Panel >> System and Security >> Administrative Tools >> Services.
  2. Find out the service “SQL Server”.
  3. Right-click on it and select “Stop”.
  4. Once again, right-click and select “Start”.
If this process fails to fix your issue,
  1. Find out other users who are using the same database. Execute this command:
    Execute SP_WHO
  2. Now, kill the process. To do so, execute:
    Execute KILL 53
    Here, “53” is the process ID. This will be found from “Execute SP_WHO”.
Now, there is no way that your database restoration will fail.
