Microsoft SqlServer Connection Info while configuration
I have this SQL server error and I cannot solve it. Also I don’t know what is causing it and I have it. I thought that is a good idea to call an expert from Techyv to help me with this. Is anyone available and also can help to fix this ? Please tell me how can this error message can be prevented ?
Thank you !
SQL Server could not configure ‘LPUAT’ as a Distributor
Addition information:
An exception occurred while executing a Transact-SQL statement or batch.
(Microsoft.SqlServer.ConnectionInfo)
TCP Provider: No connection could be made because the target machine actively refused it.
Changed database context to master
OLE DB provider “SQLNCLI11” for linked “repl_distributor” returned message “Login timeout expired”
OLE DB provider “SQLNCL11” for linked server “repl_distributor” returned message” A network-related or instance-specific error has occurred while establishing a connection to SQL Server. Server is not found or accessible. Check of instance name is correct and if SQL Server is configured to allow remote connections. For more information see SQL Server Books Online”. (Microsoft SQL Server, Error: 10061)
OK
