While developing a test case from a PBI in Visual Studio 11, I put the title and press save. After that I press on Edit with Microsoft Test Manager Button. I get the following error and the Microsoft Test Manager did not explore. How can I solve this please help?
Unable to start the application due to following error: object reference not set to an instance of an object..
Microsoft Test Manager Error: Object Reference Not Set to Instance of Object
Hello
As I found on internet this error is common for beta version of this software. As people report on forums you should check if there is already one instance of this application running in background. You can check it by pressing Ctrl+Alt+Del and then try to find this application in running processes. If there is running application kill it, if not then you should wait for official patch since lots of people report this bug and develop team is currently fixing it. Regards.
