Microsoft Visio Standard is not working
Hi everyone,
I have installed Microsoft Office 2016 in my Windows 10 Operating System and trying to use Microsoft Visio Standard using this program but an error occurred during this process. How can I fix this problem? I need experts’ suggestions to get rid of this problem.
Office
Stop, you should wait to install Office 2016
We ‘ll have to remove the following if you continue:
Microsoft Visio Standard 2013 – en-us
This app doesn’t work with Office 2016 right now. We’re working on a solution.
Answered By 590495 points N/A #185132
This error shows you incompatibility between the application you are installing, Microsoft Office 2016, and the application that is currently installed on your computer, Microsoft Visio Standard 2013. Microsoft Visio Standard 2013 is not compatible with Microsoft Office 2016. So, if you want to install Microsoft Office 2016, you have to uninstall Microsoft Visio Standard 2013.
If you still want to use Microsoft Visio, you should upgrade to the latest version, Microsoft Visio 2016. To fix the problem and install Microsoft Office 2016, first, uninstall Microsoft Visio Standard 2013. Click Start, Control Panel, and then select “Add or Remove Programs”. On the list, scroll down and select Microsoft Visio Standard 2013 and then click Uninstall or Remove.
Wait until it is finished then restart your computer if you are prompted. Next, install Microsoft Office 2016. If you need to use Microsoft Visio, go to Microsoft Visio Professional 2016. You are required to sign in using your Microsoft account. If you don’t have one, create a new Microsoft account and then sign in so you can download Microsoft Visio Professional 2016.
Microsoft Visio Professional 2016 is offered with 60-day trial period.
