Microsoft Visual Basic Run Time Error 80070057 on Importing Data to Excel
Asked By 1030 points N/A Posted on -
Hi all,
There are some new implementation to our company's database. We need to get some data from our old Excel files, so I decided to import some data from Microsoft Excel files so as not to encode it again.
When I was on the process of importing data from Microsoft Excel, I met an error that said," Cannot connect to the server at this time. Your table cannot be published".
Run-time error '-2147024809 (80070057)':
Cannot connect to the server at this time. Your table cannot be published.
I thought of a solution to this error. What came into my mind was the physical connection going to the server. But when I checked my connection, I am connected to the server. I am now wondering what else shall I check to get rid of the error.
Please help me with my problem.
Best Answer by AikenAiken
Answered By 0 points N/A #124564
This problem can be solved by the following method.
  • The problem is caused due to when the Windows is not updated.
  • You may update your Windows to solve the problem.
  • First of all click on the Start button and then right click on my computer.
  • A drop down list will appear then select the Properties.
  • When you select the properties then you saw a tab Automatic update.
  • Click on this tab, after clicking then select the Automatic update box.
  • Then computer ask the schedule for the Automatic update.
  • Then you have to give the schedule.
The other way you may have to solve the problem is:
  • Click on theStart button and select the Control Panel.
  • Then open the Automatic update icon.
  • The same windows will appear like when you click on the computer icon.
  • You may have to done the same procedure I mentioned in above.
Thank you.
Answered By 5 points N/A #124565
Hi good day,
The causes of this kind of problem are the Registry might be corrupt,  attacking of virus likes malware, and outdated Windows driver.
  • To fix this kind of issue, update your Windows driver and download Registry Repair software. This software will scan your registry and fix the error problem…
  • Just visit this site for information of that issue.
Thank you. Hope this helps.
Shenna22
