Microsoft Visual C Runtime Error
I am running Windows XP and when trying to load my saved games on it, I am getting a Runtime Error. It says, "This application has requested the Runtime to terminate it in unusual way". I don't know why it is appearing when I can very well played my saved games before. Please help me with it. Thanks a lot!
Answered By 1065 points N/A #105804
This may be because you utilizes the /GR and /MD compiler switches and you are using Version 7.0 of Msvcrt.dll and Msvcirt.dll. The is a Hotfix available from the Microsoft website. But if it doesn't work for you since some cases occurs because of incompatibility issue, try the solutions below:
1. Download the Microsoft Visual C++ Redistributable Package.
2. Perform a System Restore to put your system back to its normal state.
3. Update your display driver to the latest version.
4. Install the latest Flash player.
5. Try loading your saved games again.
