kathy stone
20 points
Posted on - 05/16/2012
I am using Visual Basic 6 with the free Finger print verification SDK. I have already installed Digital Persona Fingerprint Recognition system (U and U 4000B Reader) and created default database.
The verification and enrollment was done successfully and closed the project. When I open the project the error below occurred. Please give me a solution to solve this problem.
Here's the error message:
Runtime Error!
Program:…int_ verification _SDKFFVSDKbinwin32_x86Nffvserver.exe
Abnormal program termination
Here's the screenshot of the message:
Microsoft Visual C++ Runtime Error in Finger Verification
Hi Kathy, your problem here is with the C++ program, it has an error with the registry entries and the configuration.
This is what you need to do to solve this error;
Go to Start > Run
Type 'Msconfig.exe' in the box and click ok.
On General tab click Selective startup
On Startup tab click to clear all check boxes except for 'Mo search'
Click Ok and click Yes when prompted to restart your pc.
If the problem is not solved by these steps, you will need to delete Mosdmn.exe, and Mosearch.exe. This will disable support for faster searching and the runtime error wont be seen again.
I hope this solves your problem.
Thanks
Microsoft visual C++ runtime error:abnormal program termination can be caused by various things. It can be caused by clash of different applications, viruses or memory issues with your machine. One technique to fix this problem is to use a registry cleaner. The windows registry is an element in your PC that stores settings and different options for the operating system.
The registry cleaner, on the other hand is software that checks your registry for needless and useless items.
This software examines your windows registry to search for data that is no longer needed by the computer for it to take its normal operation.
With Microsoft visual C++ runtime error, the registry cleaner will also the same thing. It will examine your registry for causes of the issue and fix it by deleting those unnecessary items that caused the problem.
Although you can go into the registry and manually check it yourself, it is advised to use a registry cleaner. examining the registry and removing some items manually may be harmful to your machine.
You have no idea that you already removed something that is critical for your computer to function normally.
That’s a runtime error triggered by “NffvServer.exe” which caused the program to exit immediately. Since this is a runtime error, check the system requirements again and verify that your computer meets those requirements. If the program is compatible, try to uninstall and reinstall. Download the free version of Revo Uninstaller and install.
Once installed, start Revo then select the affected program among the applications and click “Uninstall.” Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then install the program back.
If you haven’t updated yet, download the latest version and update your program. Also, make sure you have the latest Microsoft Visual C++ installed. For an added info, the “NffvServer.exe” file is known as “Neurotechnology Free Fingerprint Verification Server” developed by Neurotechnology and also by Hewlett-Packard.
