Microsoft Visual C++ Runtime Error R6002
I have a problem about Microsoft Visual C++ Runtime Library. It had been showed from a long time ago. After opening my desktop computer when I browse or do some work, a dialog box comes with a message. I Don't know what to do now. Can you suggest?
Runtime Error!
Program: C:Program FilesCommon FilesJavaJava Updatejusched.exe
R6002
-floating point support not loaded
Best Answer by Bryan Miguel
Answered By 5 points N/A #115649
Hi, The causes of this kind of error are the virus attack, missing program file, to resolve this kind of problem.
Follow these steps:
1. Scan the computer using the NOD32 anti-virus.
2. Download the CCleaner software and install then run CCleaner to fix the registry to the system.
3. If the issue will not resolve disable the “jusched.exe
You can Visit this link to disable the “jusched.exe”
Please read carefully before you starting.
Thank you, hope its help
Regards;
logictor
Answered By 0 points N/A #115647
It is a common registry error, no need to be scared. You just have to install/repair the software, download the latest version of java and install it and delete the previous one. It will remove all registry errors in your software. Or you can download the registry cleaner from here
http://www.regcure.com/.
If you scan your PC from this software it will detect and clean all the registry errors.
See if the problem goes away.
Good Luck!
