anonymous
7060 points
Posted on - 09/11/2011
For the last few days I have encountered a problem about using MS Office on my desktop with the Windows XP operating system. The problem is that, whenever I went to launch MS Word, I have got the following error message
Microsoft Visual C Runtime Error windows XP
Microsoft C visual run error in XP occurs because of the COM Add-in. Remove COM add-in which is causing the issue will solve the problem.
Try below steps to resolve the problem,
Open Microsoft Office Word document.
Go to Microsoft Office Symbol and search for 'Word option'.
Select Word option and in the options displayed choose Add-ins.
There will be a drop down 'Manage ' search for it and click on GO and REMOVE the COM Add-in.
These steps must solve the problem.
Hello,Â
This scenario behind this issue is the loading failure of Com Add-in. There may be many reasons for that to result in a loading failure. Here is the most common solution in the case.Â
First make sure the Add-in is not listed under the 'Disabled items' category.
(To check the disabled items list in Office 2003: Go to help menu > About > "Disabled items"
To check the disabled items list in Office 2007: Click the office button > Go to options (at the bottom of the list) > Select Add-ins tab > Select the Disabled items from the dropdown menu > GO)
Follow this procedure to load the Add-in
Click the Office button, on the top at the left corner in any office program. [Eg: MS Word]
Click MS Word optionsÂ
From the tabs listed on the left side, click Add-ins tab and then click GO
In the Add-ins available box, select the check box next to the COM Add-in, to load it and click OK
Hope this will help.
Allen K
