Hi guys,
Have a look at the error message below. This is the only problem with my browser Opera.
For a moment, Opera stops working throwing the error message. For this reason, my online applications become distorted.
If you have an idea for the issue, please help.
Thanks in advance.
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: D:Opera Nextopera.exe
R6025
-pure virtual function call
Please refer to the below instructions in order to fix the Runtime error R6025.
* As you have received the runtime error message saying "pure virtual function call" the only option you have to fix the problem is completely removing the Opera program from your PC and reinstalling it. As this is a critical error that occurs due to corrupted program files in your OS you have to make sure to remove all registry files regarding the program from your computer.
1. Start task manager and go to "processes" menu. End the process by browsing the Opera program from the list of program names.
2. Then click on Windows "start" button and type "cleanmgr" and press the "enter" key. Then view files from all users. Browse all temporary files related to the program and clear them all.
3. Restart the computer when the program is completely removed from your computer.
4. Re-install the Opera program again to your PC.
5. This should solve the issue and if you encounter with the error message again you'll have to contact the Opera customer support or you'll have to repair your OS through a system repair disk.
