Microsoft visual C++ Runtime library. help please
Hi guys can anyone help me out about my problem please see the image below
Microsoft Visual C++ Runtime Library
The C++ error happens, try and delete these files update.exe, Updatelist.dat, patch.dat, and try to run the game. If the problem remain the same, try and install fresh copy of tantra client version, in a mean while when doing the above processes, do remember to turn your antivirus and firewall off.
Whenever you want to play the game before playing turn off your antivirus and firewall. See if the problem is solved
If the game you are playing is an online game similar to an MMORPG, try uninstalling the game from your computer then restart your machine. Then after booting the system, check your computer for any possible errors.
Use a disk utility application to check the system. After checking your hard drive, download again the game’s installer from the game’s website.
Maybe they have an updated installer together with some patches. Or maybe visit their website first before uninstalling the game from your computer so you will know if they have a new patch for the game.
Or, if you already have the previous installer of the game, just uninstall the game and then install it back using the installer you saved. It is possible that there is a corrupted file in the game’s installation folder. Be sure to close the game properly after playing it to avoid corrupting some files.
