Microsoft Visual Runtime error: Program terminated
How can I avoid this following Microsoft Visual C++ Runtime error?
I have searched online solution but I could not find so need expert’s guidance to solve this error.
I am running Windows 7 Operating System and waiting for your suggestion.
Thanks in advance.
Runtime Error!
Program: C
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application’s support team for more information.
Answered By 5 points N/A #174813
Hello Robert
In order for you to solve your problem, please do the following:
Go to Start and in the search box please type in cmd. Right click on it and select Run as Administrator. In the Command Prompt window, please type in sfc /scannow. This will show you if there are any corruption.
If this will not solve your problem, please access the link I have provided you with and download the Utility. It will clear any problems and errors cause by Microsoft Visual C++ Runtime.
Visual C++ Utility
I hope you will find this information useful.
Randolph
