I have this error caused by Microsoft Visual Studio and it seems like I still have missing DLL files from my PC, even I ran a DLL fixer. I tried to copy manually the missing DLL file on my system 32 and is not working. Please is there anyone that can help me with this error? How can I install all the possible DLL files?
Thanks!
RegSvr32
The module ‘C:WindowsSystem32IEShims.dIl’ was loaded but the entry-point DllRegisterServer was not found. Make sure that ‘C:WindowsSystem32IEShims.dll’ is a valid DLL or OCX file and then try again.
OK
Microsoft Visual Studio error dll file missing IEShims.dIl
In your case, I’m not sure if you are using the correct version of the program for your computer if you are using Microsoft Visual Studio. The indicated DLL file is already registered on the system but the problem is the DLL file seems to be incompatible with your operating system. This means, if Microsoft Visual Studio is utilizing this file then your version of Microsoft Visual Studio is not compatible with your operating system.
Since you did not mention what version of Microsoft Visual Studio you are using, it would help if you will check it yourself in the documentation files that come with Microsoft Visual Studio for the system requirements. If you are using either Microsoft Windows Vista or Microsoft Windows 7, make sure your copy of Microsoft Visual Studio supports any of these platforms.
Anyway, if you’d like to download the DLL file instead, visit ieshims.dll File Download. Download the version appropriate for your operating system. Once downloaded, unpack the ZIP file and copy the DLL file in “C:WINDOWSsystem32”. Overwrite the old file. Next, click Start, Run, and type without quotes “cmd” and hit Enter. In the command prompt, type without quotes “regsvr32 ieshims.dll” and hit Enter.
