Microsoft Windows Operating System problems
Hello all,
Most commonly used as well as the most popular operating system is Microsoft Windows.
I think all of you used any version of Microsoft Windows- such as XP, 2000, 98, Vista or Windows 2003 and lots of errors or problems could be appeared when you were using them.
These may occur while you are trying to boot your PC or are trying to turn off your Computer. Boot errors or STOP errors are shown in an eight-digit hex code but most of the time they are shown in a shorthand layout.
Such as: a STOP Error 0x0000000A is written like Stop 0xA. Mainly, these error messages are happening if there is a problem with hardware or the drivers are not running properly.
Error: STOP Error0x0000000A
A problem has been detected and Windows has been shut down to prevent damage
To your computer.
The problem seems to be caused by the following file: aries.sys
PAGE_FAULT_IN_NONPAGED_AREA
If this is the first time you've seen this stop error screen,
Restart your computer. If this screen appears again, follow
These steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
For any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
Or software. Disable BIOS memory options such as caching or shadowing.
If you need to use Safe Mode to remove or disable components, restart
Your computer, press F8 to select Advanced Startup Options, and then
Select Safe Mode.
Technical information:
*** STOP: 0x00000050 (0xFFFFFFF8, 0x00000000, 0xF9CF5C88, 0x00000000)
*** aries.sys – Address F9CF5C88 base at F9CF5000, Datestamp 424bb23f
Beginning dump of physical memory
Physical memory dump complete.
Contact your system administrator or technical support group for further assistance.
