Abram Jock
80 points
Posted on - 09/17/2012
I am using windows operating system and I am trying to login to my web server operating system in the GUI of my Intel RAID Web Console 2. Do you know the default password for this? What is the process for intel web raid reset password? I entered username Administrator but I can't find where to get the password, so I need to know how to reset this.
For Microsoft Windows OS, how to do intel web raid reset password?
Hi Abram,
Administrator is supposed to be the login for Intel Raid Web Console 2, but since it failed, you can contact the server administrator. But, if it would not help, you can follow this steps and be sure that the "Access to the computer from the network policy is "enable".
1. Restore the Administrator account to access the computer to network
2. Try to login to Intel Raid Web Console 2
3. Reboot if needed.
Usually Intel Raid Web Console 2 usually uses the password of your operating server system. You can go to this link for more information. https://www.intel.com/content/www/us/en/support.html. You can chat further for guidance.
