Hi guys,
While launching SAS 9.2 on my machine running with OS Windows 7 through Start-Program I received an error message. The screenshot of the error message is as under. I tried the same several times but no result. Have you any idea to solve the problem?
Please help me to get a remedy of this issue.
Microsoft Windows
sas.exe has stopped working
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available.
Microsoft Windows sas.exe has stopped working
Hello Jerry,
Here you showing in the screen shot is the problem of the super antispyware software. It can be corrupted when download or not the full version . Some spyware sometime will not allow certain antispyware installation. For this you can change the name of the software such as xyz.exe. You can also remove the program from add or remove program and again download it and reinstall it in your machine.
Sas.exe is not a windows process. This kind of application is created only when you installed a program on you system. This kind of application is runes by several installed programs. This error is promptly appearing because the process is terminated by an antivirus sometimes it processes viruses. It will stop when there is a newly installed program on your system.
Hi there Jerry:
I think the only solution to avoid the error before the program gets totally messed-up is to remove the program first. Uninstall it, and then install it again.
If the error still appears, then it’s time to change it. Why? Because trying to fix it will only give you head-ache. It’s time consuming. Download a new one; delete the previous/old one.
Thanks for asking,
Hi Jerry Blando
There is another Techyv post which is addressed your problem. Check out that page and get more idea.
Getting an error while working with SAS
