Microsoft windows XP network problem
The error message says “Winsock.dll file not found” ,
So I re-installed network drivers and replaced missing .dll, but the error remains same.
Please help me to resolve this error
Below are the steps to repair Winsock.dll registry entry:
1. Clock on Start > RUN
2. Type regedit and click Ok.
3. Find the below registry key and delete them.
1. Restart the computer which will make the computer to create a new Winsock registry keys.
2. Go to Network Connection and click on Internet Protocol, then Add
3. Choose Have Disk
4. Type " C:windowsinf" and click Ok
5. From the list, choose "internet protocol (TCP/IP)" and click ok
To answer your concern, there are several easy ways to fix this winsock.dll error.
First, you might want to check your recycle bin. There are instances that some computer users delete their computer’s winsock.dll accidentally.
So open up your recycle bin and if it’s there, just restore it back. Now if you keep on getting this error every time you’re on your PC and even after having this issue fixed previously, chances are you have a virus or malware in your system.
If this is the case, run your anti-virus/malware scanner to check for any malicious file that’s causing it.
