Jenya
Posted on - 09/27/2011
I work in Microsoft Word 2007 many hours per day but in previous days I have this error Word failed reading from this file and I do not know what it means, so I need help.
What is this error and how do you fix it?
Microsoft Office Word
Word failed reading from this file. Please restore the network connection or replace the floppy disk and retry
Microsoft Word Error: Word failed reading from this file
This error is due to two reasons if you are working in an Office and reading from the directory which is shared in the Office network then the file that you are reading is corrupted of your access is denied.
In this case you do that try to renew your connection to the directory and try again to access the files but this time don't open the files directly you should have to copy the file and then open it on your own computer.
And if you are not using the shared directory and you are trying to open the file from a CD floppy then the it is so sure that your file is corrupted.
Thanks
