Microsoft Word Font Automatically Changes
I am using Microsoft Word 2007. It is causing problem of auto font changing to Vrinda. Where can I change the default Font setup and how to stop Font Changing?
To change the default font and to stop the automatic font changing on your computer, click the Home tab under the MS Word toolbar. Expand the Font menu and then click the small box that look like the image below:
To view a font, select to highlight it and then look on the Preview below. When you already find the font you want, just leave it highlighted and then choose the font style and size. Click the Default button on the bottom and then click OK. Your selected font will be your default font.
There are different ways to keep this from happening. I only know of three and see if any of these works out for you.
1. While on Microsoft Word, press ctrl+shift+f. Set the font t hat you want to use as default and then press “default” button on the lower left.
2. Second is changing the “Styles”. Right click on the normal style and select modify. Choose the font that you want to use.
3. Lastly, by turning off the automatic update on your Microsoft word.
I hope I was able to help you.
