Rham Jhen
Posted on - 12/06/2011
Hello Guys here! I don’t know how or what cause why my Microsoft word installed on my computer always gets an error every time I save my file. It’s only on my one file. But on another word file works fine. I don’t know why this file always get’s an error. Please give me some Idea why Microsoft word generates this error. Thanks.
Error
Microsoft Word has generated an error and will be closed!
OK
Try opening the file (the one which always gets this error) alone. Do not open other Microsoft Word documents and then do the long cut method which is File > Save As. Then select File > Exit Word. If this does not solve the problem, close the file again and try re opening it with the Open and Repair feature of Microsoft Office. A part of the document or the Microsoft Program could be damaged during the last time you opened it and needs to be repaired. Another way to figure this out is copying the whole content of the Word document to a blank word file. Press Ctrl + A to copy the whole content then open a blank Word file then press Ctrl + V to paste. Thank you.
Charlyn June
