Microsoft Word has stopped working
Dear Friends,
I am face lots of problem in Microsoft Office 2007. following a problem is one of them. Now I am thinking I should go back to Office 2002.
I guess it was the best version of Office. So far, the following error occur when I try to close and save the program
(Microsoft Word). Is this any fault of my installation process or any software malfunction?
A problem caused the program to stop working correctly. Please close the program.
Best Wishes,
Roxy
Best Answer by smithgood
Answered By 0 points N/A #90410
These type of errors sometime may occur due to the windows you have installed, is it working properly, exe files are not missing from it. But almost this type of problem occur due to the unregistered of the MS word, so make the registry adjustment. For getting it please visit and just click on to the “Start Orb” and than type the regedit in to the search box and must be press enter. So please go to the each option given below and make of your choice the appropriate changings.Just reach at and make like this, CURRENT_USER/Software/Microsoft/Office/Word
Modify Addins -> oldAddins
Than,       CURRENT_USER/Software/Microsoft/Office/12.0/Word
Modify Data -> oldData
Modify Options -> oldOptions
In the end,  LOCAL_MACHINE/Software/Microsoft/Office/Word
I f modifying REGISTRY settings are  incorrectly it can cause serious problems which may prevent your computer from to the properly boosting. Microsoft do not  guarantee about  any problem  from the configuring of REGISTRY settings have to must  be solved These type of modifications are on at your own risk.
Answered By 10 points N/A #90411
