Hello Guys, how are you all today?
I have a problem and I hope that I find anyone know how to solve it.
My error is related to the printers, I have bought a HP Printer and I have windows XP running on my laptop.
I have office 2003 on my laptop and I want to print a document, but when o clicked on print I found the following error :
Microsoft Word
No printers are installed. To install a printer, point to Settings on the Windows Start menu, click Printers, and then double-click. Add Printer. Follow the instructions in the wizard.
Any help please, I can’t use my new printer till now and I want to print many things.
I don’t know where does the error come from to begin solving it.
Thanks
EU GENE
MS-Word Error: No printers are installed
If you found the following error on your laptop using ms word 2003 to print the document. You can follow these steps:
Install the printer driver on your PC
Add Printer
Select Local Printer, click Next
Select Create a new port and select 'Standard TCP/IP Port', click Next and Next
Enter the IP address of your printer, click Next, click Finish
Click 'Have Disk', navigate to where you installed the printer driver and select the INF file, click Open, click OK
The rest of the prompts may differ from printer to printer but should be self-explanatory; the printer then installs
Microsoft Word 2003 now correctly sees the printer
Check the compatibility of the printer with your windows by visiting this site.
To install the printer on your PC, do the following:
1. Attach the printer to your computer
2. From the Start menu hover over Settings, then click on Printers and Faxes
3. Double click on Add Printer
4. Click on Next
5. Click Local printer
6. Uncheck the Automatically detect and install
7. Click Next
8. Click Create a port
9. Click Local port in type of port box
10. Type the patch of the printer in this manner: \print server nameprinter name
11. Click next
12. In the next page, select your printer from the list
13. Click next
14. Click finish
15. Your printer is installed
16. Again go to the printers and faxes
17. Right click on the printer, then click properties
18. In general tab, click print test page
If it is still unusable, install a support template and try to troubleshoot with the help of it.
Microsoft Word 2003
1. From the Start menu go to control panel
2. Click add or remove programs
3. Click o change or remove a program
4. Select Microsoft office (or the version of it) from the list
5. Click to change
6. Click add or remove features
7. Click to change
8. In custom setup, check chooses advanced customization of applications
9. Click next
10. From Choose update options for applications and tools list
a. Click to expand Microsoft Office Word
b. Click to expand Wizards and Templates
c. Click more templates and macros
d. Click run from my computer
11. Click Update
