I am using Microsoft Works which are like an office suite but with less features. Something weird is happening such that almost all operations are paralyzed. I am getting an error as shown below. Please advise.
Microsoft Works
Works cannot access one or more files it needs to run the Calendar. The files may have been renamed, deleted or moved. Try reinstalling Works, and then starting the program again.
Microsoft Works which is Office suite shows error Message
Hi Arthur
I have read your problem. In fixing this calendar data base it should be replace.
To do that insert the installation disk to a CD or DVD Drive.
Then go to my computer/open documents and settings or program data/open Microsoft/works there is a file there named Mskwscal.wcd right click and rename it to old_Mskwscal.wcd
Then open installation works disk folder right click Mskwscal.wcd and then copy it Then go to works again paste it there then right click and click properties/general and uncheck the "Read only".
